Eljay
Cirrus
Jan 31, 2017STREAM::expression problem
Hi, I am trying to replace a -tag using STREAM::expression. It works if the tag is on a new line, but if the tag follows directly after another tag (ex: ) then it fails.
Here's my code:
STREAM::expression {@<\/body>@@}Does anyone know how to fix this?
Thanks,
Lars J
- crodriguezRet. Employee
I tried it with this minor change and it worked fine:
STREAM::expression {@@@}I removed the backslash in the first body tag (<\/body> changed to ). I am using BIG-IP v12.1. In my HTML, the final line of HTML code reads:
