Ben_Kennedy_502's avatar
Ben_Kennedy_502
Nov 17, 2006
Stream not working
Hello,
I've tried using stream for the first time to alter a string returned (in XML) from http to https. I have the profile assigned to the virtual which seems to have done absolutely nothing.
profile stream soapfault_profile {
defaults from stream
source "http://www.url.co.uk:81/"
target "https://www.url.co.uk/"
I therefore implemented a rule as I was told it might have to be activated:
rule soapfault_rule {
if { [HTTP::method] eq "POST" } {
STREAM::enable
log local0.warn "stream enabled " }
else {
STREAM::disable
log local0.warn "stream not enabled"
Both the rule and stream profile are applied to the vip.
As it's XML the request is a POST and when I test I can see the log firing, however the string is still coming back unaltered. Does anyone know what might be causing this please?
  • hoolio's avatar
    hoolio
    Is the string that you want to replace located in the HTTP data (as opposed to the headers)? Can you log the HTTP::payload command output to verify the string is there?
    Also, what version of BIG-IP are you running?
    Aaron
  • Hi,
    It turns out the string wasn't there, I was testing manually not realising my request was used in the repsonse (host) so it seems to be working. I do have a problem now with the Content length being too short following the stream replacement. I shall have a look around the forum though as I imiagine that must pop up quite a lot.
    Thanks,
    Ben
  • hoolio's avatar
    hoolio
    Good to hear you figured it out. Deb posted a solution for the content length issue you're encountering (Click here):
    Change Response Chunking to "Rechunk" on the http profile for that virtual.
    Aaron
  • Hi,
    That's fixed it, almost! Is stream a bit flaky? I've been testing myself, and occasionally the stream doesn't seem to have been replaced, even though I'm sending the same request and receiving the same responses.
    when HTTP_RESPONSE {
    set ::soap_stream_in "http://[clientside {[HTTP::host]}]:81"
    set ::soap_stream_out "https://[clientside {[HTTP::host]}]"
    if {[HTTP::header Content-Type] contains "xml"} {
    STREAM::enable
    STREAM::expression "@$::soap_stream_in@$::soap_stream_out@"
    log local0.warn "@$::soap_stream_in@$::soap_stream_out@"
    STREAM::disable }
    The rule should only be matching things with xml in the content-type response,but the capture below shows the rule should be matched but the url is not being redirected to https. I can't see why it only fails intermittently when the same request is sent time after time and works 90% of the time, any advice would be grateful:
    POST /Services/CallIdL1/CallIdL1.asmx HTTP/1.1
    User-Agent:Mozilla/4.0(compatible; MSIE 6.0; MS Web Services Client Protocol 1.1 .4322.2032)
    Content-Type:text/xml; charset=utf-8
    SOAPAction:"urn:callcredit.plc.uk/soap:callidl1api/Search"
    Content-Length:1863
    Expect:100-continue
    Host:host.com
    HTTP/1.1 100 Continue
    xml request
    HTTP/1.1 500 Internal Server Error.
    Date: Mon, 20 Nov 2006 15:47:59 GMT
    Server: Microsoft-IIS/6.0
    X-Powered-By: ASP.NET
    X-AspNet-Version: 1.1.4322
    Cache-Control: private
    Content-Type: text/xml; charset=utf-8
    Transfer-Encoding: chunked
    1f5
    soap:Client.InvalidJobId
    Invalid OjJobId.
    http://host.com:81/Services/CallIdL1/CallIdL1.asmx
    0
    read:errno=0
