Stream Logging Efficiency - iRule question
I have an iRule that utilizes stream matching and header capture to pull a Client IP, a posted Username, and a response from the web application (webapp is ADFS in this case).
I am not sure if this is the most efficient method to gather and log this data; the iRule works well in our dev environment, but I am concerned that it will be hog on prod.
FWIW - I know this could be done more efficiently with APM but I'm constrained to an iRule for this at the moment.
Any advice to improve the rule would be appreciated!
Snag the Remote Client address
set int [IP::remote_addr]
Insert MS Proxy info for ADFS to know we are external
HTTP::header insert "X-MS-Proxy" "F5-LTM-PROD"
Insert MS Proxy info for ADFS Logging
HTTP::header insert X-MS-Forwarded-Client-IP [IP::client_addr]
if {[HTTP::method] eq "POST"}{
Trigger collection for up to 1MB of data
if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576}{
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
Check if $content_length is not set to 0
if { $content_length > 0} {
HTTP::collect $content_length
when HTTP_REQUEST_DATA {
foreach X [split [string tolower [HTTP::payload]] "&"] {
if { $X starts_with "username" } {
set USER $X
when HTTP_RESPONSE {
if { [HTTP::header value Content-Type] contains "text/html"}
STREAM::expression @Incorrect@
STREAM::enable
when STREAM_MATCHED {
log local0. "ADFS FAILED Login attempt for user $USER From Client $int"
log local0.info "ADFS FAILED Login attempt for user $USER From Client $int"
- cjunior
Nacreous
Hi dude, I maybe do it like the this:
when HTTP_REQUEST { If is not the logon page, nothing to do now and then You must change to your real logon page address if { [string tolower [HTTP::path]] ne "/adfs/ls/idpinitiatedsignon.aspx" } { event HTTP_RESPONSE disable return } event HTTP_RESPONSE enable Snag the Remote Client address set int [IP::client_addr] Insert MS Proxy info for ADFS to know we are external HTTP::header insert "X-MS-Proxy" "F5-LTM-PROD" Insert MS Proxy info for ADFS Logging HTTP::header insert X-MS-Forwarded-Client-IP $int if {[HTTP::method] eq "POST"}{ Trigger collection for up to 1MB of data if { [HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] ne "" } { if { [HTTP::header "Content-Length"] <= 1048576 } { set content_length [HTTP::header "Content-Length"] } else { set content_length 1048576 } Check if $content_length is not set to 0 if { $content_length > 0 } { HTTP::collect $content_length } } } } when HTTP_REQUEST_DATA { Search for username=theName set USER [findstr [string tolower [HTTP::payload]] "username=" 9 "&"] } when HTTP_RESPONSE { if { [info exists USER] && [HTTP::header value Content-Type] contains "text/html" } { if { [HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576 } { set content_length [HTTP::header "Content-Length"] } else { set content_length 1048576 } if { $content_length > 0 } { HTTP::collect $content_length } } } when HTTP_RESPONSE_DATA { if { [string match "*Incorrect*" [HTTP::payload]] } { log local0. "ADFS FAILED Login attempt for user $USER From Client $int" log local0. "ADFS FAILED Login attempt for user $USER From Client $int" log local0. "ADFS FAILED Login attempt for user $USER From Client $int" } }Feel free to check the performance and comment the code.
Respectfully
