aandreyy_293459
Oct 10, 2017stream iRule not working with reg
hi
i have stream iRule that change all http to https:when HTTP_REQUEST { tell server not to compress response HTTP::header remove Accept-Encoding
disable STREAM for request flow
STREAM::disable
} when HTTP_RESPONSE {
catch and replace redirect headers
if { [HTTP::header exists Location] } {
HTTP::header replace Location [string map {"http://" "https://"} [HTTP::header Location]]
only look at text data
if { [HTTP::header Content-Type] contains "text" } {
Replace http:// with https:// UNLESS the original string is http://www.w3.org
STREAM::expression {@http//@https://@}
enable STREAM
STREAM::enable
and need bypass url not changing to https, but when i am adding something like STREAM::expression {@http:(?!//@} I am getting
can't compile regular expression - (http:(?:?!//))
have any ideas how to do it in other way?
