elvisc_26948
Feb 24, 2010STREAM expression not working
The replacement doesnt seem to work...I am basically doing URI replacment using STREAM function.
Snippet of my code:
http_request {
STREAM::expression "@abc@abc?zzz=123@"
STREAM::enable
I have profile stream added to vip.
- hoolio
The stream profile only operates on the payload. The URI is in the HTTP headers, so you wouldn't want to use a stream profile and iRule for this. Also, for HTTP, it's not practical to use a stream profile and iRule on a request payload if the search/replace fields are a different length as there is no way to update the Content-Length header.
With that said, you can use HTTP::uri or HTTP::path to rewrite the URI or path in a request. You can use string map to search for one string and replace it with another.
Can you give a more exact example of what you're trying to replace in the URI?
Here is an example that would do exactly what you've tried. But I don't think it will solve the problem if abc is a fairly generic string in the URI.when HTTP_REQUEST { Replace abc with abc?zzzz=123 in the URI HTTP::uri [string map {abc abc?zzzz=123} [HTTP::uri]] }
Aaron - elvisc_26948
Hi Hoolio,
I tried the method before but the thing is that it does replaces the uri but not the subsequent uri the client is requesting... and thats why I went with STREAM expression. I have seen people on F5 forum using it in the HTTP_REQUEST...btw, how do I turn on debug to see if the STREAM expression is doing the replacement correctly? that would help for debugging...
thx. Hoolio for your help. - hoolio
Is the URI you want to rewrite found in the HTTP response headers or the response payload?
Can you use a browser plugin like HttpFox for Firefox or Fiddler for IE to check this?
To rewrite a URI in the response headers, you can use HTTP::is_redirect and HTTP::header. To rewrite the response payload, you can use a stream profile and STREAM::expression iRule.
Here is an example iRule that was designed for rewriting the host in URLs. You could adapt it to handle the URI also (add code to HTTP_REQUEST to rewrite the URI).
HTTP Respond Data replacing?
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=3457134602
Aaron - hoolio
Good to hear you got it fixed.
Aaron
