Strange traceroute to virtual server,Multiple interfaces found
Hi All.
I found decrease connection from EVC IP 10.70.11.9 to 10.64.41.45 ( TIBCO VS LB).
From LAN, tracert -d 10.64.41.45
Tracing route to 10.64.41.45 over a maximum of 30 hops
1 3 ms 1 ms 5 ms 10.103.10.1 2 2 ms 1 ms 17 ms 10.1.0.201 3 5 ms 1 ms 3 ms 10.1.4.149 4 269 ms 8 ms 1 ms 10.1.4.129 5 8 ms 2 ms 4 ms 10.1.4.202 6 4 ms 15 ms 2 ms 10.64.41.45
Trace complete.
- And traceroute from server
$ traceroute 10.64.41.45 traceroute: Warning: Multiple interfaces found; using 10.64.1.57 @ ce0 traceroute to 10.64.41.45 (10.64.41.45), 30 hops max, 40 byte packets 1 10.64.1.2 (10.64.1.2) 0.512 ms 0.722 ms 0.454 ms 2 10.1.4.202 (10.1.4.202) 1.046 ms 1.064 ms 0.962 ms 3 10.64.41.45 (10.64.41.45) 0.865 ms 0.838 ms 0.793 ms 4 10.64.41.34 (10.64.41.34) 673.197 ms !H * * 5 * 10.64.41.34 (10.64.41.34) 3153.394 ms !H * 6 * 10.64.41.34 (10.64.41.34) 2111.558 ms !H * 7 * * 10.64.41.34 (10.64.41.34) 3152.685 ms !H 8 * * 10.64.41.34 (10.64.41.34) 2101.687 ms !H 9 * * * 10 10.64.41.34 (10.64.41.34) 3161.913 ms !H * * 11 10.64.41.34 (10.64.41.34) 2101.745 ms !H * * 12 * 10.64.41.34 (10.64.41.34) 3161.819 ms !H * 13 * * 10.64.41.34 (10.64.41.34) 991.176 ms !H 14 * * 10.64.41.34 (10.64.41.34) 4271.387 ms !H 15 * * * 16 10.64.41.34 (10.64.41.34) 3151.230 ms !H * * 17 10.64.41.34 (10.64.41.34) 2101.607 ms !H * * 18 *
and what should i do and i check?
because im new in F5, sorry lads/
thank you
- adithyodw_18563
herewith the screenshot, tracert from LAN and from Server
This is IP VS : 10.64.41.45 Self Ip External VLAN :10.64.41.34
please review the following article. http://www.tek-tips.com/viewthread.cfm?qid=193701
- adithyodw_18563
Hi Sir, can you give me the details how to solved it? and my another question is : 1) Why the traceroute show up like that? 2) Form LAN is OK, But from server is like thah 3) If always like that if we tracert to VS?
