Anilmoh_177241
Feb 02, 2015Storefront/Xendsktop 7.5 Native Features missing from f5.citrix_vdi.v2.0.0
We are using Big-IP F5 to provide LTM + APM Services for Citrix Xendeskop/XenApp 7.5 Environment with Storefront 2.5.
- XenDesktop toolbar is not available, making it very tough to navigate between multiple xendesktop sessions.
- Session pin to all available monitors. We prefer to have option of limiting display to single monitor in multi-monitor configuration.
- Storefront Favorite application feature not available through Citrix Receiver.
- Launching Receiver from inside Xendesktop session disconnect the parent session. We have Both application and Desktop published through single URL and Delivery Controller.
- Angelo
Hi
Try remove all optimization profiles and test, optimization usually messes up things when using F5 with citrix. Citrix will just recommend a second rate NetScaler piece of *&^%
post a view traffic dumps so i can see the traffic. if you need the commands just let me know
- Angelo
and you need to ensure that the ICA port is open though the F5 i think it's tcp 1494
