Jellf_42492's avatar
Jellf_42492
16 years ago
step to monitor f5
Hi All,
there is a step to monitoring our f5 machine from log ?
i found this log at /var/log/message
notice syslog-ng[5054]: Configuration reload request received, reloading configuration;
it's seem f5 reload the config, but i cannot find who do this...
need a suggestion from dev member to check it
BR
  • Hey Jellf,
    'history' command should say about the last 500 lines implemented
    'last' command will show who logged in
    Cheers,
    Roger
  • Hi Roger,
    I just found this message from /var/log/message, i think thereis a jobs do this continously every day at the same time 04.02 AM.
    how we can figure it ? how we can find which script or application to this at f5.
    need your help
  • Hi. This log entry is caused by cron (/etc/crontab), which executes /etc/cron.daily/logrotate at ~04:02 by default. The logrotate configuration files specify that logrotate should restart after files are rotated. So what you are seeing is a message from logrotate restarting after the log-rolling process has completed.
