outofsight_6960
Oct 08, 2009STATISTIC_CPU_INFO_FIVE_MIN_AVG_USAGE_RATIO
Using the iControl API I need to get the host cpu usage as a percentage.
A call to System::SystemInfo::get_all_cpu_usage_extended_information gives me the following 'STATISTIC_CPU_INFO_FIVE_MIN_AVG_USAGE_RATIO', but I cant find any reference to that in the SDK docs.
Could someone confirm if this is what I need?
Thanks in advance.
- iloveniu_38329
hello
could you tell me how to use System::SystemInfo::get_all_cpu_usage_extended_information function?
i need some sample code, thanks!
