standby device is rebboting,once active device went faulty F5 ltm(4000)
F5 ltm(4000) series active device went faulty,satndby device is rebooting every 3 seconds,why standby is rebooting
- Simon_Blakely
Employee
Do you have any error logs or the output from the LTM console?
If your system has a Service Contract, raise a service request with F5 Support.
- manjunatha_DN_3
I checked in bash mode tail -f /var/log/ltm I can able to view Present logs ,How to check 5and 6 hour back logs
- Simon_Blakely
Employee
You need to search in the ltm log file for the time period of interest
grep /var/log/ltmif the logs have been compressed you can use zcat
zcat /var/log/ltm.2.gz | grep - jaikumar_f5
Noctilucent
This is weird,
No device can go on boot and come back that up. Are you referring 3 mins ?satndby device is rebooting every 3 secondsAlso search your /var/log/ltm with some keywords
There will be logs indicating why your device is going on reboot.boot, reset, restart, action - manjunatha_DN_3
Thanks bro
- manjunatha_DN_3
zcat /var/log/ltm.2.gz,using this command I checked ,lot of logs missed
