sso problem with ntlm2
Hello guys Im newbie to F5 APM i use f5 ver 12.00 im trying to set SSO via NTLMV2 i can access the website but
when looking at the /var/log/apm i see "Could not find SSO username, check SSO credential mapping agent setting" The ntlm2 sso is configured USERNAME SOURCE "session.sso.token.last.username" PASSWORD SOURCE "session.sso.token.last.password"DOMAIN SOURCE "session.logon.last.domain" THE ACCESS PROFILE POLICY IS ASSOCIATED WITH SSO NTLM2 AS WELL AS THE PORTAL RESOURCE ITEM when i use curl -i https://x.abc.com -k i see that the site is working with ntlm
HTTP/1.1 401 Unauthorized Server: Microsoft-IIS/7.5 WWW-Authenticate: NTLM MicrosoftSharePointTeamServices: 14.0.0.7015 X-MS-InvokeApp: 1; RequireReadOnly Date: Mon, 21 Dec 2015 16:56:51 GMT
any help will be appriciate Tia Tal
- stan_piron
Cumulonimbus
you must create a box "SSO Credential mapping" in VPE to store in "session.so.token.last.username" and "session.so.token.last.password" username and password from logon page.
- Talassa_90150
thank you where is this vpe store ?
- Talassa_90150
HI i almost have the same config but i use reverse proxy "Portal" with "AD reosurce Assign" my ntlm2 sso is the same as u posted and The sso "Credentiol Mapping" is session.sso.token.last.username session.sso.token.last.password
the portal config has
Match Cae for paths is [yes] applicaton uri https://abc.comresource item paths /* hostname https://abc.com sso configuration is "ntlm2"
- Talassa_90150
Hi Its working !!! thank you very much for your help
- THi
No probs, did you figure out what was the problem?
- Talassa_90150
The F5 log reported "Invalid NTLM type 2 message received for SSO configuration" and this is causing the f5 to cancel the authentication !! in other word the sharepoint/IIS web site is sending two 401 header "WWW-Authenticate:NTLM" At the moment there is nothing i can do in the F5 i openned a ticket to the sharepoint webmaster to fond out why m i getting 2 401 header's
im going to install zap/owsap to get more details The case was documented in SOL17417
