Moinul_Rony
Altostratus
Sep 22, 2014SSL offloading not working with X-Forwarded-Proto
Hi we are trying to SSL offload on F5 using the following iRule but it seems its not changing the header X-Forwarded-Proto
HTTP::header insert "X-Forwarded-Proto" "https";
We are getting the following 400 response from server
Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Hint: https://www.website.com/
Any idea?
- tatmotiv
It seems as if you're trying to talk plain, unencrypted http to an https service on the server. You should either enable a server side ssl-profile for this virtual or change the destination port of your pool members to the one that is listening for unencrypted http.
