Robert_Decker_2
Jun 18, 2007ssl ocsp Irule help needed
I have a virtual server that serves pages to clients with and without client certificates. Those users with a client certificate will need to be verified against an ocsp server and have an http header inserted that says "cert auth = pass". That part seems to work fine. Those without a certificate would need to be forwarded to the pool members with an http header inserted that says "cert auth = failed".
The users without a certificate go to auth_wantcredential and then fail. I see “CLIENTSSL_CLIENTCERT: application verification failure” in the log.
How would I write an Irule that allows a client without a cert to skip the ocsp verification, but verifies those that do have a certificate? I am currently working with version 9.3.
Thank you for your help,
rob
- Robert_Decker_2
Below is my Irule:
when CLIENT_ACCEPTED {
set tmm_auth_ssl_ocsp_sid [AUTH::start pam default_ssl_ocsp]
use the following logging line for troubleshooting only
log local0. "Client Address: [IP::client_addr]"
when CLIENTSSL_CLIENTCERT {
Check certificate validity
set ssl_cert [SSL::cert 0]
set ssl_errstr [X509::verify_cert_error_string [SSL::verify_result]]
Set results in the session so they are available to other events
0=The certificate, 1=The validation error, 2=Revocation status
set ssl_stuff [list anything1 anything2 anything3]
lset ssl_stuff 0 $ssl_cert
lset ssl_stuff 1 $ssl_errstr
lset ssl_stuff 2 ""
session add ssl [SSL::sessionid] $ssl_stuff 180
Check revocation status of the certificate with the OCSP servers
AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]
AUTH::cert_issuer_credential $tmm_auth_ssl_ocsp_sid [SSL::cert issuer 0]
AUTH::authenticate $tmm_auth_ssl_ocsp_sid
set id [SSL::sessionid]
SSL::handshake hold
Log results
log local0. "Client IP: [IP::remote_addr]"
when AUTH_SUCCESS {
if {$tmm_auth_ssl_ocsp_sid eq [AUTH::last_event_session_id]} {
OCSP servers say the certificate is good
SSL::handshake resume
lset ssl_stuff 2 "success"
session add ssl $id $ssl_stuff
when AUTH_FAILURE {
OCSP servers say the certificate was revoked
lset ssl_stuff 2 "failure"
when AUTH_ERROR {
An error occurred communicating with the OCSP servers
lset ssl_stuff 2 "error"
when AUTH_WANTCREDENTIAL {
OCSP servers want more info?
reject
Retrieve certificate information from the session
set ssl_stuff2 [session lookup ssl [SSL::sessionid]]
log statements below are to allow admin to view cert results through logs
log local0. "Client IP: [IP::remote_addr], requesting: [HTTP::method]/[HTTP::host][HTTP::uri], browser: [HTTP::header User-Agent], Referer: [HTTP::header exists Referer], HTTP version [HTTP::version], Persitance Cookie: [HTTP::cookie exists JSESSIONID], SSL: [SSL::cipher name]/[SSL::cipher version]/[SSL::cipher bits]"
if { $ssl_stuff2 == "" } {
No certificate was supplied, set CertAuth to "Fail" so the
webservers know the user was not authenticated via OCSP
log local0. "Cert Auth = Failed"
HTTP::header insert CertAuth "Fail"
A certificate was supplied
set ssl_cert2 [lindex $ssl_stuff2 0]
set ssl_errstr2 [lindex $ssl_stuff2 1]
set ssl_revoke2 [lindex $ssl_stuff2 2]
log local0. "Certificate Information, Trusted Certificate Validation: $ssl_errstr2, OCSP Revocation Statue: $ssl_revoke2"
if { $ssl_errstr2 eq "ok" } {
The certificate has passed Trusted Certificate Validation
Below are the OCSP states
switch $ssl_revoke2 {
"error" {
HTTP::redirect "http://10.1.1.1/errorcert.html"
log local0. "OCSP error was redirected"
"failure" {
version of verisign cert is not in OCSP server--must allow without verifying revocation status
if { [X509::issuer $ssl_cert2] contains "OU=verisign" } {
log local0. "Cert is from verisign, Cert issuer - [X509::issuer $ssl_cert2]"
HTTP::header insert CertAuth "Pass"
HTTP::header insert SSLClientCertSubject [X509::subject $ssl_cert2]
The cert was actually in OCSP server as a revoked cert
HTTP::redirect "http://10.1.1.1/revokedcert.html"
log local0. "Revoked certificate was redirected"
"success" {
The certificate is valid, the user is authenticated.
Add the certificate subject so the web servers can lookup the
the user's account and priviledges
default {
We should not get here, I don't know what happened
log local0.error "Invalid revocation status = $ssl_revoke2"
reject
The certificate was invalid.
we should not get here
HTTP::redirect "http://10.1.1.1/invalidcert.html"
log local0. "Invalid certificate was redirected"
Thanks again for any help!
rob
