Ajit's avatar
Ajit
Jun 22, 2018
SSL handshake failure using serverssl (F5 and Citrix Netscaler)
Hello F5 Experts,
I am getting fatal ssl handshake failure(40) right after the server hello message from the Citrix Netscaler which sits and the vendor location. I can see in wireshark that the TLS protocol & ciphers between the F5 and Netscaler are matching so not sure what else it could be. The serverssl profile is failing and the party on the other side has Citrix netscaler. We have F5 LTM at our end.Also, the citrix netscaler presents a wildcard cert to us as part of SSL termination. Could that be a problem for the F5?
Below are few logs from the ssldump output:
New TCP connection 7: 10.104.41.138(56218) <-> 10.104.40.136(443)
7 1  1529673027.5089 (0.0001)  C>SV3.1(121)  Handshake
      ClientHello
        Version 3.3
        random[32]=
          46 f9 98 03 10 6c 14 84 4f 11 4e 81 f0 a0 92 dd
          15 07 84 70 8c c4 94 c4 4d 2c ee 76 df d3 34 32
        cipher suites
        Unknown value 0xc02f
        Unknown value 0xc030
        Unknown value 0x9c
        Unknown value 0x9d
        Unknown value 0xc027
        Unknown value 0xc028
        Unknown value 0xc013
        Unknown value 0xc014
        TLS_RSA_WITH_AES_128_CBC_SHA256
        TLS_RSA_WITH_AES_256_CBC_SHA256
        Unknown value 0xc012
        TLS_RSA_WITH_3DES_EDE_CBC_SHA
        Unknown value 0xff
        compression methods
                  NULL
3 2  1529673027.5333 (0.0299)  S>CV3.3(74)  Handshake
      ServerHello
        Version 3.3
        random[32]=
          5b 2c f5 46 8d 5d 9a 7e 02 10 6e 1c 90 3f d6 02
          cb 4c be 17 cb 7c 0c 1f 55 c8 77 fc bd 85 21 88
        session_id[32]=
          73 0d 48 68 8d da 73 e5 77 07 3a dc 47 a2 51 40
          88 32 a2 3e d6 5c 3a 6b 4e dc c8 2c 28 d2 3c 27
        cipherSuite         TLS_RSA_WITH_AES_256_CBC_SHA
        compressionMethod                   NULL
3 3  1529673027.5333 (0.0000)  C>SV3.3(2)  Alert
    level           fatal
    value           handshake_failure
2    1529673027.5333 (0.0306)  S>C  TCP RST
3    1529673027.5334 (0.0000)  C>S  TCP RST
Please advise. Any help with this would be really appreciated.
Thank you!
  • can you change Secure Negotiation to Request and test
  • Ajit's avatar
    Ajit
    Hello Anesh,
    Your answer is correct. After making the requested changes the issue got resolved. Thanks for your help! 🙂
    I want to highlight few points with which it was confirmed that this is an HSTS issue:
    1) Warning message in the LB logs as below:
    18:40:24 LBNAME warning tmm1[23850]: 01260017:4: Connection attempt to insecure SSL server (see RFC5746) aborted: 10.104.40.136:443
    2) Openssl command which clearly indicates the problem:
    `New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES128-GCM-SHA256
    Server public key is 1024 bit
    -->> Secure Renegotiation IS NOT supported <<--
    Compression: NONE
    Expansion: NONE
    Also, the same problem has been highlighted in K13860
    Regards,
    Ajit
    • David_M's avatar
      David_M
      which openssl command are you referring to?
      The basic openssl s_client ?
  • Ajit's avatar
    Ajit
    Hello Anesh,
    Compression: NONE
    Expansion: NONE
    Regards,
    Ajit
  • Ajit's avatar
    Ajit
    Hello Anesh,
    Please can you post your answer in the answer section? In the comment section I cannot mark it as an answer.
    Regards,
    Ajit
  • Anesh's avatar
    Anesh
    In your ServerSSL profile, can you try updating Secure Renegotiation from Require Strict to Request
