Anesh's avatar
Anesh
May 10, 2017
SSL Forward proxy Bypass iRule not working
The below irule does not Bypass SSL forward proxy function for url's defined in the Bypass datagroup, it continues to re-sign with the certificate provdied by F5...
when CLIENTSSL_CLIENTHELLO {
    if { $static::DEBUG } { log local0. "in event" }
    set sni_exists [SSL::extensions exists -type 0]
    if { $sni_exists } {
        binary scan [SSL::extensions -type 0] @9a* tls_servername
        if { $static::DEBUG } { log local0. "tls_servername = ${tls_servername}" }
when CLIENTSSL_SERVERHELLO_SEND {
   if { [class match $tls_servername contains Bypass] } {
    log local0. "Data group match"
    SSL::forward_proxy policy bypass
    HTTP::disable
    pool bluecoatpool
  • Anesh's avatar
    Anesh
    Get below error when doing curl to ssl explicit forward proxy vip
    * About to connect() to proxy 10.13.22.6 port 8080 (0)
    *   Trying 10.13.22.6... connected
    * Connected to 10.13.22.6 (10.13.22.6) port 8080 (0)
    * Establish HTTP proxy tunnel to www.365online.com:443
    > CONNECT www.365online.com:443 HTTP/1.1
    > Host: www.365online.com:443
    > User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1l zlib/1.2.3 libidn/0.6.5
    > Proxy-Connection: Keep-Alive
    < HTTP/1.1 200 Connected
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Proxy replied OK to CONNECT request
    * successfully set certificate verify locations:
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSLv3, TLS handshake, Client hello (1):
    } [data not shown]
    * Unknown SSL protocol error in connection to www.365online.com:8080
    * Closing connection 0
    curl: (35) Unknown SSL protocol error in connection to www.365online.com:8080
  • This should work. Do you have the SSL Forward Proxy Bypass option enabled in the client and server SSL profiles?
  • Anesh's avatar
    Anesh
    It works for Urls which are not part of the Bypass datagroup, but for urls within Bypass datagroup it does not work
  • On of the primary issues here is timing. In your iRule, you're redirecting traffic to the bluecoat pool in the CLIENTSSL_SERVERHELLO_SEND event. Presumably you have another pool that is default for traffic.
    When a client enters the SSL forward proxy VIP, he'll initiate the SSL handshake.
    Client Hello
    which is then paused. At that point, the server side goes out and performs a complete server side TCP connection and server side SSL handshake with the server, brings the server's cert back, and only then does the client side SSL session resume.
    client side server hello send
    So by the time you get to the CLIENTSSL_SERVERHELLO_SEND event, an initial server side connection has to have already left through the default path, so setting the pool in this event is too late. Try this:
            pool bluecoat-pool
            catch { HTTP::disable }
  • Anesh's avatar
    Anesh
    Below iRule works
     when CLIENT_ACCEPTED {
    log local0. "[IP::client_addr]:[TCP::client_port]: New TCP connection to destination [IP::local_addr]:[TCP::local_port]"
    HTTP::disable
    SSL::disable clientside
    SSL::disable serverside
    TCP::collect
    set destip1 [IP::local_addr]
    log local0. "$destip1"
    if { (![class match $destip1 equals BypassDestIP])}
    virtual EgressANYVIP
    else
    translate address enable
    translate port disable
    pool BluecoatProxyPool
    when CLIENT_DATA {
    set destip [IP::local_addr]
    log local0. "$destip"
    binary scan [TCP::payload] c type
    if { $type == 22 and (![class match $destip equals BypassDestIP])}
    SSL::enable clientside
    SSL::enable serverside
    HTTP::enable
    TCP::release
