SSL errors during load test
We are currently load testing an application and receive SSL errors when reaching a certain number of users. We have tested using two different scripts, at one script, the SSL errors occur at 900 users, when running the other script, the errors begin at 1200 users. No errors are shown in the Big-IP log. The SSL errors that occur on the script are Error -27780: [GENERAL_MSG_CAT_SSL_ERROR]connect to host “name of url” failed: [10045] Connection reset by peer.
I am leaning towards this being a script error since two scripts produce errors at different user counts. However, I want to rule out any issues on the F5. We are running version 11.3 HF8.
Is this something anyone has run across?
Thanks.
- Kevin_K_51432Historic F5 Account
Hi MNB, This appears to be more of an application layer issue (than SSL). It's very vague currently. A great initial t-shooting step might be to enable RST logging. This is basically logging some additional diagnostic with each RST:
http://support.f5.com/kb/en-us/solutions/public/13000/200/sol13223.html
Hope this offers some help, Kevin
If the RST logging doesn't prove helpful, here's some good info on SSL debug logging:
Enabling SSL debug logging
https://support.f5.com/kb/en-us/solutions/public/15000/200/sol15292.html?sr=39449817
Kevin
- mnb_63148
Thanks, Kevin. I apologize for the vagueness. I was not initially involved in the beginning of the troubleshooting and did not have a packet capture at the time. I now have a capture. C-> S SSLv2 Client Hello C<- S SSLv3 Server Hello C<- S SSLv3 Continuation Data C<-S SSLv3 Continuation Data, Continuation Data C->S Client Key Exchange C<-S Change Cipher Spec, Encrypted Handshake Message C->S Application Data C<-S Continuation Data C->S Encrypted Alert C->S RST, ACK It looks like the client-side/load-tester side is initiating the Reset. Also, the record layer at the beginning is SSLv2 and the Handshake Message is SSLv3. We are on 11.3 HF8 and it does not support SSLv2 in its default cipher suite. However, the client-side still sent Application Data/A GET Request to F5.
- mnb_63148
Below is a screenshot of the SSLv2 part of the frame.
Hi NMB, changeCipherSpec is a good sign typically. Also some application data is sent. I think probably some issue with app layer. Did you try RST diagnostic? Maybe something in your application logs?
Kevin
