SSL certificate issues with Lync 2013
I'm trying to verify the certificate with Lync 2013 but I keep getting error messages when I attempt to verify.
openssl verify -purpose sslclient -CAfile /config/filestore/files_d/Common_d/certificate_d/:Common:clyncweb.crt_41052_1 /config/filestore/files_d/Common_d/certificate_d/:Common:clyncwebCA.crt_41060_1
/config/filestore/files_d/Common_d/certificate_d/:Common:clyncwebCA.crt_41060_1: /C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert High Assurance EV Root CA error 18 at 0 depth lookup:self signed certificate OK
Currently I'm running on 11.4.1HF3. Any advice on where to go next with my troubleshooting?
- Kevin_K_51432Historic F5 Account
Greeting Zuke, I put the client cert first and got the same error. Swapping client and CA certs in the parse order seems to have fixed this:
openssl verify -purpose sslclient -CAfile auser.crt client_auth-ca.crt client_auth-ca.crt: C = CA, ST = CA, L = CA, O = CA, OU = CA, CN = ca.com error 18 at 0 depth lookup:self signed certificate OK openssl verify -purpose sslclient -CAfile client_auth-ca.crt auser.crt auser.crt: OKHope that helps, Kevin
