Clayton_63491
May 28, 2009SSL Certificate Info put in HTTP Header after Renegotiate
I am trying to create a virtual server that can route traffic to different pools based on the URI, and can require client certificates only for specific URI patterns.
When the client certificates are required, I need to renegotiate the SSL and pass the client certificate subject in an http header to the pool destination. I need to be able to change the SSL profile to “clientprofile_1IBE_LCMX_cert_required” before the renegotiate so that the browser will present only certificates issued by a certain CA.
I have found numerous examples of pieces of this and have created the scenario below. It works as far as requiring a client cert only for the URI that begins with /certreq, but I then the request never gets sent to the selected pool.
In looking at my debug statements in the log, it looks like the HTTP_REQUEST_SEND event is not triggered after the SSL::renegotiate is done and the client certificate is sent. Is there something else that I have to do to release the http request after the SSL::renegotiate.
I am a newbie with irules, so any help would be appreciated. We are using version 9.4.7.
virtual vs_1IBE_MyApp {
snat automap
pool pool_1IBE_App1_dev
destination 192.168.1.18:20000
ip protocol tcp
rules irule_1IBE_ssl_renegotiate
httpclass
http_1IBE_LCMX_App1_a0
http_1IBE_LCMX_App2_a0
profiles
clientprofile_1IBE_LCMX_nocert
f5-dev-crypto-server
http
oneconnect
tcp
rule irule_1IBE_ssl_renegotiate {
when CLIENTSSL_CLIENTCERT {
log local0. "MyApp SSL verify_result is [SSL::verify_result]"
log local0. "MyApp SSL cert count is [SSL::cert count]"
set certcnt [SSL::cert count]
if { $certcnt > 0} {
log local0. "LCMatrix client certificate found. HTTP::release"
set ssl_cert [SSL::cert 0]
set ssl_subject [X509::subject $ssl_cert]
log local0. "LCMatrix client certificate subject is $ssl_subject for session [SSL::sessionid]"
session add ssl [SSL::sessionid] $ssl_subject 1200
log local0. "MyApp client certificate found. HTTP::release"
HTTP::release
log local0. "MyApp request received for [HTTP::uri]"
if { [HTTP::uri] starts_with "/certreq" } {
set ssl_subject [session lookup ssl [SSL::sessionid]]
log local0. "MyApp client certificate required for: [HTTP::uri]"
if { $ssl_subject equals "" } {
log local0. "MyApp client certificate not found. Holding HTTP request until a client cert is presented..."
HTTP::collect
SSL::authenticate always
SSL::authenticate depth 9
SSL::cert mode require
SSL::renegotiate
when HTTP_REQUEST_SEND {
clientside {
if { [HTTP::uri] starts_with "/plintl00" } {
pool pool_1IBE_LCMX_App2_a0
HTTP::header insert "X-SSL-Client-Cert-Subject"[X509::subject [SSL::cert 0]]
log local0. "MyApp subject header inserted [X509::subject [SSL::cert 0]]"
log local0. "MyApp request sent for [HTTP::uri]"
profile clientssl clientprofile_1IBE_LCMX_cert_required {
defaults from clientssl
key "keyf5cloudtest.key"
cert "cerf5cloudtest.crt"
client cert ca "ca-CommercialRSA.crt"
peer cert mode ignore
profile clientssl clientprofile_1IBE_LCMX_nocert {
key "default.key"
cert "default.crt"
profile serverssl f5-dev-crypto-server {
defaults from serverssl
key "datapower_cert.key"
cert "datapower_cert.crt"
chain none
ca file none
ciphers "DEFAULT"
passphrase "abcdefghij"
options
dont insert empty fragments
modssl methods disable
renegotiate period indefinite
renegotiate size indefinite
unclean shutdown enable
strict resume disable
handshake timeout 60
alert timeout 60
cache size 20K
cache timeout 3600
profile httpclass http_1IBE_LCMX_App1_a0 {
defaults from httpclass
pool pool_1IBE_LCMX_App1_a0
redirect none
url rewrite none
asm disable
paths "/App1*"
profile httpclass http_1IBE_LCMX_App2_a0 {
redirect none
asm disable
paths "/App2*"
pool pool_1IBE_LCMX_App1_a0 {
monitor all https
members 192.168.1.18:10000
pool pool_1IBE_LCMX_App2_a0 {
monitor all https
members 192.168.1.18:20000
- Clayton_63491
I noticed that after the SSL::renegotiate, the CLIENTSSL_CLIENTCERT event is triggered. The HTTP::release in the CLIENTSSL_CLIENTCERT event does not cause the HTTP_REQUEST_SEND event to be triggered. So the HTTP request is never sent to the pool. Is there any known problems in 9.4.7 that would prevent the HTTP::release from releasing the HTTP payload? - spark_86682Historic F5 AccountThat looks like it should work, but there's a lot going on and I didn't look in-depth. Can you add a line that logs in HTTP_REQUEST_DATA, just to see if that event fires after the HTTP::release?
- hoolio
Did you ever figure this out? Was it a post request? I wonder if you removed the HTTP classes whether it would affect the issue.
Aaron - hoolio
Actually, was the pool down, by chance? I saw HTTP_REQUEST_DATA not trigger in a test for a related iRule (Click here) when the pool was down.
On the other hand, TMM was crashing for me on 9.4.7 when I tested with a client presenting a valid cert.
Aaron
