KLetourneau_229's avatar
KLetourneau_229
Sep 26, 2018
SSL bridging and Exchange 2010 hybrid
Hello,
We are attempting to use the exchange hybrid wizard to configure our Exchange 2010 environment for O365 migration. The wizard runs fine, but we are not able to get the MRS proxy working due to our SSL offloading configuration at the F5. We would like to configure the Exchange VIP using SSL bridging - is it as simple as adding a server SSL profile? The CAS servers are listening on 443, and have a valid cert installed. I created a server SSL profile using the same cert as the client SSL profile, and my Outlook client was unable to connect. Is there something I am missing?
  • None of my pools are passing traffic on 443, they are all set to use port 80 - so that was my issue. I think I will use a separate VIP for this purpose, as a "performance (Layer 4)", and pass all SSL traffic directly to the CAS pool.
