Muhammad_57196
Aug 09, 2009SSH weird problem
I had a weird problem while trying to SSH to one of the F5. Sometime it works fine with SSH and sometime i got the following message:
"ssh_exchange_identification: Connection closed by remote host".
But nothing is being changed on that F5. I am not sure why is it let me in via SSH sometime but gave the above error message when i tried to do SSH.
Can anyone please help me. Forgive me if i paste this in the wrong forum.
Regards,
Muhammad
- hoolio
Hi Muhammad,
I think this is an issue specific to SSHD--not much of anything to do with BIG-IP. You could try searching the web for this error message. There are quite a few forum posts with troubleshooting suggestions. You could try running a new instance of sshd with debug enabled:
http://mrraph.net/WordPress/?p=16
/usr/sbin/sshd -d -p 2200
and then connect on port 2200. Or you could change the LogLevel in /config/ssh/sshd_config to debug, reload the config using kill -HUP `pidof sshd`and then retest.
Here are some related links:
http://archive.netbsd.se/?ml=openssh-unix-dev&a=2007-10&t=5430083
I suspect you're hitting the MaxStartups unauthenticated connection
limit. It default is 10, try bumping it on the servers to, say, 30 or 40.
http://lists.mindrot.org/pipermail/openssh-unix-dev/2008-February/026176.html
> Hi,
> I'm getting this error when I ssh to the servers.
> I added /etc/hosts.allow and it actually worked once and if I tried again I get the same error.
You did not mention whether you added by name or by IP.
Every time I've seen this error it has been a DNS problem. And I only
see this on systems that are in hosts.allow by name.
Aaron - Elias_O_16228
I just wanted to add my comment on this old thread because I ran into similar issue when I was synchronizing FIPS Security Domain "ssh_exchange_identification: Connection closed by remote host" and was able to fix it by going to system>platform>ssh IP allowed: ensure the the peer ip address is added or "select allow all"
Regards
Elias_O - Gilles_MOULIN_1
If you are trying to connect to self IP (no managment IP) on LTM running V10, it may fails on the non default route-domain. I faced such issue when exchanging key with a GTM (bigip_add). Afterward, the iquery connection can use any self ip.
