hidnt_36310's avatar
hidnt_36310
Feb 20, 2009
ssh connection
Hi there,
I'm new with F5 LMT unit. Right now my configuration allow http load balance. However, I can't ssh either of the two members in the pool outsite of the 10.1 subnet.
What do I need to do to allow ssh to the members?
  • If you are trying to reach the management port address and you are off-net (as indicated) you will need a management route to your location. If you are trying to get to a TMM self-ip (configured in the networking section of the GUI) then you'll need a TMM route to the gateway between the LTM and you. Make sure the self-IP configuration and the packet filtering (if configured) allows your access.
  • Sorry,
    I was my stupid mistake. Instead using port 22 I typed port 21 (ftp).
