  • Hi,
    the below is how to change the SSH cipher suites,
    To modify MAC
            tmsh modify sys sshd include "MACs hmac-sha1,hmac-ripemd160,[email protected]"
            tmsh save sys config partitions all
            tmsh restart sys service sshd
    To modify ciphers
                tmsh modify sys sshd include "Ciphers aes128-ctr,aes192-ctr,aes256-ctr"
  • Hi,
    I have BIG-IP 11.6 and looks like that theese two commands (for MACs and ciphers) are mutually exclusive, for example, if I enter:
    Configuration of SSH deamon looks like:
        sys sshd {
            banner enabled
            banner-text "Any unauthorized access is strictly prohibited
        and will be prosecuted to the full extent of
        applicable local and international law.
        All access is monitored."
            inactivity-timeout 900
            log-level verbose
    If after that I enter:
    Configuration looks like:
    sys sshd {
        banner enabled
        log-level verbose
    How can I change ciphers and MACs together, because I need to disable CBC encryption anf MD5 and 96-bit MAC algorithms?
    • refra_151287's avatar
      refra_151287
      Icon for Cirrus rankCirrus
      Hi Mate, It's really what happened with me, but after doing the performing PenTest again, I found the changes happened, you can check that and feedback us.
  • I tried, but situation is like I described before.
    This commands are used to change dynamicly generated SSH daemon (/var/run/config/sshd_config).
    For example, here is configuration of SSHD on TMOS:
    sys sshd {
    banner enabled
    log-level verbose
    As you can see, MAC is modified and this can also bee seen in auto generated configuration (just part of it) of ssh daemon below:
     THIS IS AN AUTO-GENERATED FILE - DO NOT EDIT!!!
     $OpenBSD: sshd_config,v 1.74 2006/07/19 13:07:10 dtucker Exp $
     Use the tmsh shell utility to make changes to the system configuration.
     For more information, see tmsh -a help sys sshd.
     KexAlgorithms diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
     MACS hmac-md5,hmac-sha1,hmac-ripemd160,[email protected],hmac-sha1-96,hmac-md5-96
     The strategy used for options in the default sshd_config shipped with
     OpenSSH is to specify options with their default value where
     possible.
     F5 Note
     If a directive appears multiple times, its first instance will be used
     and subsequent instances will be silently ignored. The following options
     have been configured via 'tmsh sys sshd include' and will therefore take
     precedence over any conflicting setting that appear afterward. Conversely,
     certain directives are placed before 'include' section to prevent being
     overridden.
     F5 - end of options specified via 'tmsh sys sshd include'.
    Port 22
    Protocol 2,1
     Protocol 2
     AddressFamily inet6
     F5 - these are FIPS approved ciphers.
     Ciphers aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
     It's best to leave this setting as it is and use "tmsh modify sshd allow".
     An even better idea is to make sure that your self-IPs do not allow traffic
     on port 22.This is the default, so installations are secure by default.
    ListenAddress 0.0.0.0
    ListenAddress ::
     HostKey for protocol version 1
    HostKey /config/ssh/ssh_host_key
     HostKeys for protocol version 2
    HostKey /config/ssh/ssh_host_rsa_key
    HostKey /config/ssh/ssh_host_dsa_key
     Lifetime and size of ephemeral version 1 server key
    KeyRegenerationInterval 1h
    ServerKeyBits 768
     Logging
     obsoletes QuietMode and FascistLogging
    SyslogFacility AUTH
    As you can see, MACs are modified and default ciphers are used.
    If after that we change ciphers, configuration looks like:
    sys sshd {
    banner enabled
    log-level verbose
    And auto generated ssh daemon looks like:
     possible.
     F5 Note
     overridden.
    Port 22
    Protocol 2,1
     Protocol 2
     AddressFamily inet6
    ListenAddress ::
    ServerKeyBits 768
     Logging
    SyslogFacility AUTH
    A you can see, there is no configuration line for MACs, just for ciphers.
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      support case will get you the best / quickest answer at this stage in my opinion. please do report back what they say.
    • aries22's avatar
      aries22
      hi guys!
      how can I see the auto generated configuration of ssh daemon?
  • I opened support case and aolution is prety simple:
    It looks like it's working. 🙂
    TMOS configuration of SSH after applying command:
    sys sshd {
        banner enabled
        include "
    log-level verbose
  • I opened support case and engineer gave me a solution. It's pretty simple:
    It look's like it's working. 🙂
    TMOS comnfiguration of SSH now look's like:
    sys sshd {
        banner enabled
        include "
        log-level verbose
  • Hi mate I am heaving same problem as you before. When I apply following command I got error. Can you please advise if I am applying it correctly.
    tmsh modify sys sshd include "MACs hmac-sha1,hmac-ripemd160,[email protected] Ciphers aes128-ctr,aes192-ctr,aes256-ctr"
    Thanks Syed
  • Did you c/p exactly as I wrote?
    Ciphers have to be in separate line from MACs.
    BR, Mate
  • Confirming changes have been applied to F5 mgmt/config interfaces:
    Red Hat article https://access.redhat.com/solutions/420283 is related to this topic and provides some simple remote confirmation tests we all know and love via ssh client parameters.
    1. verify remotely from SSH client ssh -vv -oMACs=hmac-md5 10.x.y.z . . .output snipped . . . no matching mac found: client hmac-md5 server hmac-sha1,hmac-ripemd160
    2. verify remotely from SSH client ssh -vv -oCiphers=aes128-cbc 10.x.y.z . . .output snipped . . . no matching cipher found: client aes128-cbc server aes128-ctr,aes192-ctr,aes256-ctr
