Splitting TCP payload and load balancing
I am receiving data over a single TCP connection which at present gets sent to one the the pool members in the pool attached to the VIP. The data received is actually a stream of identifiable chunks of data. My intention is to collect the data, split it and to send it on the the pool as separate TCP packets and have these packets round robinned to the two members of the pool.
I can collect the data from the TCP connection in CLIENT_ACCEPTED and can begin to process the payload in CLIENT_DATA but I am not sure how or in which event to invoke the pool member selection.
Can anybody throw me a pointer?
fergu5
- nitass
Employee
i did a bit test using \n as message boundary. client is netcat and server is echo streamserver. firstly i used 10.2.4 hf4 but having an issue about multiple messages per packet (e.g. 1\n2\n3\n). anyway, one message per packet (e.g. 1\n) seems okay.
i suspected it might be bug 383853. there is engineering hotfix available on 11.1.0 hf4, so i applied it and it seems a bit better. tcp::notify eom is command from the engineering hotfix. it is used to release parsed message. tcp::notify request/response is used in the past.
Bug 383853 - Need a synchronous event to signal end of message from TCP rule event
not sure if this is what you are looking for. anyway, this is my testing. hope it helps.root@ve11enghf(Active)(/Common)(tmos) show sys version| grep -i -A 3 product Product BIG-IP Version 11.1.0 Build 2185.38 Edition Engineering Hotfix HF4 root@ve11enghf(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.19.252:7 ip-protocol tcp mask 255.255.255.255 pool foo profiles { mblb { } tcp { } } rules { myrule } snat automap vlans-disabled } root@ve11enghf(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:7 { address 200.200.200.101 } 200.200.200.111:7 { address 200.200.200.111 } } } root@ve11enghf(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when CLIENT_ACCEPTED { log local0. "--" log local0. "[IP::client_addr]:[TCP::client_port] > [IP::local_addr]:[TCP::local_port]" TCP::collect } when CLIENT_DATA { set idx 1 log local0. "--" log local0. "received [TCP::payload]" while {$idx <= [TCP::payload length]} { if {[TCP::payload $idx] ends_with "\n"} { log local0. "sent [TCP::payload $idx]" TCP::release $idx TCP::notify request TCP::notify eom set idx 1 } else { incr idx } } TCP::collect } when SERVER_CONNECTED { log local0. "--" TCP::collect } when SERVER_DATA { set recvidx 1 log local0. "--" log local0. "[IP::remote_addr]:[TCP::remote_port] > [IP::local_addr]:[TCP::local_port]" log local0. "received [TCP::payload]" while {$recvidx <= [TCP::payload length]} { if {[TCP::payload $recvidx] ends_with "\n"} { log local0. "sent [TCP::payload $recvidx]" TCP::release $recvidx TCP::notify response TCP::notify eom set recvidx 1 } else { incr recvidx } } TCP::collect } } A. single message per packet clieint [root@centos251 ~] nc 172.28.19.252 7 1 <--- (type in) 1 <--- (echo response) 2 2 3 3 log [root@ve11enghf:Active] config tail -f /var/log/ltm Feb 11 09:41:17 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:17 tmm info tmm[8822]: Rule /Common/myrule : 172.28.19.251:49509 > 172.28.19.252:7 Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : received 1 Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : sent 1 Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : 200.200.200.111:7 > 200.200.200.10:49509 Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : received 1 Feb 11 09:41:19 tmm info tmm[8822]: Rule /Common/myrule : sent 1 Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : received 2 Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : sent 2 Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : 200.200.200.101:7 > 200.200.200.10:49509 Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : received 2 Feb 11 09:41:20 tmm info tmm[8822]: Rule /Common/myrule : sent 2 Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : received 3 Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : sent 3 Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : 200.200.200.111:7 > 200.200.200.10:49509 Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : received 3 Feb 11 09:41:21 tmm info tmm[8822]: Rule /Common/myrule : sent 3 B. multiple messages per packet client [root@centos251 ~] cat data.txt 1 2 3 4 5 6 7 8 9 10 [root@centos251 ~] nc 172.28.19.252 7 < data.txt 2 4 6 8 10 1 3 5 7 9 log [root@ve11enghf:Active] config tail -f /var/log/ltm Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : 172.28.19.251:49513 > 172.28.19.252:7 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : received 1 2 3 4 5 6 7 8 9 10 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 1 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 2 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 3 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 4 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 5 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 6 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 7 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 8 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 9 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 10 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : 200.200.200.111:7 > 200.200.200.10:49513 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : received 2 4 6 8 10 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 2 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 4 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 6 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 8 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 10 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : -- Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : 200.200.200.101:7 > 200.200.200.10:49513 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : received 1 3 5 7 9 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 1 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 3 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 5 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 7 Feb 11 09:44:01 tmm info tmm[8822]: Rule /Common/myrule : sent 9
