Song_chi_woon_2's avatar
Song_chi_woon_2
Oct 30, 2006
specific page fallback
Hi
I want to do redirection about specific page
We usee to script shell order to the redircetion in BIGIP to a node or pool base
when session arrived at the critical level I want How to use iRule which it about a specfic page redirection procedure
ex> http://dnshop.daum.net/front/event/FallSale?Sid=0001_2D020000_01_00
  • hoolio's avatar
    hoolio
    If I understand you correctly, you should be able to do this with connection limits on the nodes in the pool and a rule which redirects on the LB_FAILED event. Check out DrTeeth's post for more detail: (Click here)
    Colin has a related example as well (Click here)
    Aaron
