rolf's avatar
rolf
Icon for Cirrus rankCirrus
Apr 16, 2018
SNMP MIB: CPU Temperature
Hi guys,
we saw, that the i-Series of the BigIP Appliances (i2000 and i4000) misses the CPU Temperature in the MIB Base. Also the tmsh: "show sys hardware" shows no information regarding that metric. This information used to be available in the former Hardware.
Does somebody has a workaround? Or is it a feature? ;)
Thanks, Rolf
  • I asked this question to F5 Support. Answer is:
    There is no CPU Temperature on these Systems accessible.
    You might want to use 'tmctl sensor_measurement_table' command to create custom MIBs.
    K13596: Creating custom MIB entries on the BIG-IP system https://support.f5.com/csp/article/K13596
    Rolf
