Seven11's avatar
Seven11
Dec 29, 2017
SNMP for CPU, Memory and Disk Usage
Ive got 3 different Hardware Setups (Bigip i5600, i2600 and i7800).
1. What are the correct OIDs if i want to check the Hardware:
  • CPU Usage (not every core / just one single result)
  • Memory Usage (for the whole hardware system if possible)
  • Disk Usage (for the whole hardware system if possible)
2. What are the correct OIDs if i want to check the VCMP Guests on the i7800:
  • CPU Usage
  • Memory Usage
  • Disk Usage
There are a lot on the MIB Files and Results but which are the OIDs you want use in this case?
