e_howl_26497's avatar
e_howl_26497
Apr 07, 2009
Snat for transparent device
I came across a request to setup LTM to load balance some transparent proxy devices. There are some unique requirements, wonder if I can get some advice here.
[Scenario]
Origin Servers (Internet)
|v
Client --> LTM -> Proxy2
v|
Proxy1
3.3.3.3
Traffic flow:
- In scenario 1, Client initiates HTTP request to Origin Servers via a Virtual Server on LTM (e.g. 2.2.2.2:xxx).
- LTM forwards the request to Proxy1 (e.g. 3.3.3.3).
- Proxy1 will then initiate another outbound request via another VS on LTM (e.g. 0.0.0.0:yyy), which is then redirected to Proxy2 (use irule).
- Proxy2 again initiates another request to the Origin Servers.
- Return traffic need to follow the flow sequence back
Challenge:
- The proxies are transparent devices, in other words, they preserve the Client's source ip throughout. LTM only sees the requests from Proxy1/Proxy2 as coming from the Client source IP.
- Question: is it possible to use irule to maintain/keep track of the connections between Proxy1/Proxy2/LTM as LTM only sees the Client's IP
I thought of turning on SNAT for every connections that come from Proxy1/Proxy2, but am not sure if it will work. It seems LTM will also need to keep track of the connections in Layer 2.
VS 0.0.0.0:80
-> irule1
set client_ip [IP::addr [IP::client_addr]]
if { [TCP::server_port] == 80 } then
pool Proxy1
snat $client_ip
Any thoughts are appreciated. Thanks.
