SNAT Automap - Connection mirroring
Hello,
can anyone help me to figure out how to enable connection mirroring when I use SNAT Automap?
In the SOL13478 (https://support.f5.com/kb/en-us/solutions/public/13000/400/sol13478.html), it gives the next command:
modify /ltm snat mirror enabled
But when I apply to my configuration, it displays an error:
modify /ltm snat automap mirror enabled
01020036:3: The requested SNAT (automap) was not found.
Thanks. Regards,
- Vijay_E
Cirrus
If you are using this:
`modify /ltm snat mirror enabled`< snat > is referencing the name of the SNAT pool created and not automap. I think making sure that the VS has mirroring enabled will suffice in your case. You would have to enable SNAT mirroring if you have created SNAT pool that will be utilized by servers to initiate traffic via the F5 SNAT Pool IP.
This command allow connection mirroring for a SNAT object. If you are using Automap in your Virtual Server SNAT settings, you don't have to enable connection mirroring for SNAT because the way to choose a SNAT IP addr is always the same. You can find more info here :
SOL7336: The SNAT Automap and self IP address selection
