Pantelis_Karbal
May 02, 2008SMTP load balance
Hello,
Attempting to load blamance my SMTP servers however I need to "preserve the clients original IP" for loging etc...
Is there any way to do so ? Stop the LTM from doing the SNAT/NAT and preserving the original IP ?
Thanks in advance for any information !!!
Pantelis
- Ryan_Korock_46Historic F5 AccountPantelis,
Modifying the source IP address via SNAT is an option that is most commonly used in order to ensure server responses are properly routed back through the BIG-IP, however it is not required for SMTP load balancing if your internal routing is set up correctly. If your SMTP servers will already route response traffic back through the BIG-IP without having the BIG-IP modify the source IP, then you can go ahead and disable SNAT on the Virtual Server, and your SMTP servers will 'see' the true source IP of the connection.
Let me know if this helps
-Ryan - Reuben_Turner_7
Hello all,
I have this same issue but my SMTP servers are not directly connected to the same LAN as my F5's. IS there a solution to this query based on this scenario. Please advise.
Regards,
