SIP Monitor question
I have problem with SIP health check.
F5 send a SIP OPTIONS request on UDP port 5060 to the SIP server. The SIP server reply with SIP/2.0 200 OK but include SDP in the answer and some how F5 does not like the answer and the server is mark down . Below is the output from monitor loggin
SIP: Sending:
'OPTIONS sip:10.105.111.20:5060 SIP/2.0
Call-ID: [email protected]
CSeq: 1327894037 OPTIONS
Via: SIP/2.0/UDP autd00f5-cc02.vodafone.com.au:5060;branch=z9hG4bK263386c0
Max-Forwards: 1
To: sip:10.105.111.20
Content-Length: 0
Received:
SIP/2.0 200 OK
Content-Length:133
To:;tag=ah_2C59067U1.UBB
Via:SIP/2.0/UDP autd00f5-cc02.vodafone.com.au:5060;branch=z9hG4bK263386c0
Call-ID:[email protected]
CSeq:1327894037 OPTIONS
Allow:ACK,BYE,CANCEL,INFO,INVITE,NOTIFY,OPTIONS,PRACK,PUBLISH,REFER,SUBSCRIBE,UPDATE
Content-Type:application/sdp
Content-Disposition:session;handling=required
v=0
o=- 0 0 IN IP4 0.0.0.0
s=-
c=IN IP4 0.0.0.0
t=0 0
m=audio 0 RTP/AVP 18
b=AS:8
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
Don't recognize this as our reply...
8567: down
Any suggestions what can be wrong
Ignat
- jerome_grenier_
The "To" header in the response is lacking a URI... Maybe that's the issue?
Hope this helps!
- writemike
For anyone else stuck on this, it ended up being bug ID534458 which causes the 200 OK to be ignored since the F5 can't parse the response due to the lack of whitespace in the response. You can see it in the example shown in Ignat's question. There is a EngHF for 11.6.0 HF6 if you need it.
