mahir's avatar
mahir
Feb 01, 2018
simplesaml as SP and F5 as IDP
can anyone help me to configure the simpleaml as SP and F5 as IDP. according to the logs I arrive at even that IDP sends assetion where there is the mail. on the other hand side simpleamlphp he can not see and authenticate the mail
  • Can you share the errors you get in simplesamlphp and in your F5? I have done this before and it works just fine. Enabling APM SSO debuging in you F5 will help you a lot.
    Verify you have imported properly your metadata files in both sides.
