Simple sharepoint lab problem
hi out there I started just in trying to publish SharePoint 2010 trough the F5 (11.3 with LTM & APM) - I am just playing around now to see how it Works. I am starting with a simple LTM proxie - where I hit the first problem and I can't find the right answer (or just don't understand it) - see - when I try to open the site it does a redirect to another uri: Oct 14 22:43:42 bigip1 info tmm[7591]: Rule /Common/log_headers : Client 195.81.253.32:1069 -> sp01/sites/titest/ (response) - status: 302 Oct 14 22:43:42 bigip1 info tmm[7591]: Rule /Common/log_headers : Content-Type: text/html; charset=UTF-8 Oct 14 22:43:42 bigip1 info tmm[7591]: Rule /Common/log_headers : Location: http://sp01/sites/titest/SitePages/Home.aspx Oct 14 22:43:42 bigip1 info tmm[7591]: Rule /Common/log_headers : Server: Microsoft-IIS/7.5
it does a redirect from /sites/titest to /sites/titest/SitePages/Home.aspx but it doesnt look to me as if this redirect is passed through to the client. How does I get it redirected ?
best regards /ti
- tiwang
hi Again Thanks a lot Arnaud - this did the trick
best regards /ti
- Arnaud_Lemaire
Employee
can you try this:
when HTTP_RESPONSE { if { [HTTP::status] == "302" } { if { [HTTP::header "Location"] starts_with "http://" } { HTTP::header replace "Location" [string map {http https} [HTTP::header "Location"] ] } } } - tiwang
hi Again ok - what is happening is of course this "stupid" redirect problem - since the SharePoint webserver is running on a non-encrypted site (port 80) the redirect is handled in this way - which of course not is accessibly by the client - when the request is done to:
https://sp01.dom1.dk/sites/titest/
the webserver will issue a 302 with location set to:
http://sp01.dom1.dk/sites/titest/SitePages/Home.aspx
and this is passed trough to the client
I need a irule which will catch a 302 and change the http to https in the URL - should be pretty simple - but stupid me is a bit in doubt where to start - there must be lots of these samples here but in fact I can't find - help....
best regards /ti
- tiwang
Hi Arnaud
I have done a dump on the f5 but I can also do a fiddler on the client - I can post the result on monday. What I have seen until now is that if I instead of using the "default top level" which issues the redirect instaed tries to launch /sites/titest/SitePages/Home.aspx I can get the session up but the redirect doesnt Work. best regards /ti
- Arnaud_Lemaire
Employee
Hello tiwang, could you run a browser plugin or web Dev tools to make sure about response you receive at the client side ?
- tiwang
hi Again - really noone which can give me a Little hint?
