Abe_11636's avatar
Abe_11636
Icon for Cirrus rankCirrus
Sep 14, 2011
simple irule not forwarding
this is my irule: (for a vip on 443)
if { [HTTP::host] eq "http://aira.coxnet.cox.net"} {
HTTP::redirect "https://aira.coxnet.cox.net/airnetProp[HTTP::uri]"
It doesnt get forwarded; if I type in the url it goes in fine
The irule order is the last 1
member: Windows server with IIS ( it would easy to do a url forward from iis
Thanks for any advise
Joe
  • HTTP::host only only contains the host (e.g. aira.coxnet.cox.net) not the protocol. So, the expression in your conditional will always evaluate to false.
    Incorrect:
    Better?:
    if { [HTTP::host] eq "aira.coxnet.cox.net"} {
  • I see two things with your rule.
    First, is that [HTTP::host] is never going to be a full URL. The host portion of the request would be "aira.coxnet.cox.net". Your rule will never match an HTTP host because you will never get one that looks like the one in your rule.
    Second, you say this is rule is on an HTTPS vip. Any requests going to this vip are going to be of the form, "https://aira.coxnet.cox.net/???". It looks like what you are trying to do is redirect HTTP requests to HTTPS. If you want all traffic to go over HTTPS, you could configure a vip listening on port 80 and add a rule that redirects all requests to HTTPS. It might look something like this:
      HTTP::redirect "https://[HTTP::host][HTTP::uri]"
    You could always check the HTTP host on that if you wanted which would make it look like this:
      if {[HTTP::host] equals "aira.coxnet.cox.net" } {
    Richard
  • Crap. I had two examples there but one of them got lost...
    The first one was the blanket redirect all traffic to HTTPS:
    The modification to it was the addition of the HTTP host check:
    Richard
  • It looks like you are also trying to force SSL. So, you need to also check the protocol:
    if {[TCP::local_port] equals "80"} {...
    or maybe...
    if {[HTTP::host] eq "http://aira.coxnet.cox.net" and [TCP::local_port] equals "80"} {...
  • pls feel free to revise.
    [root@orchid:Active] config  b virtual bar443 list
    virtual bar443 {
       snat automap
       destination 172.28.17.88:https
       ip protocol tcp
       rules myrule
       profiles
          clientssl
          http
          tcp
    [root@orchid:Active] config  b rule myrule list
    rule myrule {
         if {[string tolower [HTTP::host]] equals "aira.coxnet.cox.net"} {
    [root@orchid:Active] config  curl -Ik https://aira.coxnet.cox.net/test123
    HTTP/1.0 302 Found
    Location: https://aira.coxnet.cox.net/airnetProp/test123
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 0
