Randy_Johnson_1
Mar 18, 2010Simple iRule, confusing output ...
I'm using a fairly simple iRule to prove that my BigIP is not addiing excessive latency to a transactiona gainst our WebServices.
The rule looks like this:
set http_request_time [clock clicks -milliseconds]
set request_log_line "\
[HTTP::request_num],\
[IP::remote_addr],\
[HTTP::method],\
[HTTP::uri]\,
[HTTP::host],\
[LB::server]\
when HTTP_RESPONSE {
set http_response_time [ clock clicks -milliseconds ]
log local0.info "$request_log_line,\
[HTTP::status],\
[expr $http_response_time - $http_request_time]"
While (for the most part...) ther logged output makes sense
Mar 18 11:40:15 tmm tmm[1586]: Rule RJTime_Test : 63, IP::remote_addr removed, POST, /ourapp.asmx, oursvchost.ourdomain.net, Service 10.1.1.114 80 , 200, 47
I also get lines like this...
Mar 18 11:40:15 tmm tmm[1586]: Rule RJTime_Test : 1, IP::remote_addr removed, POST, /ourapp.asmx, oursvchost.ourdomain.net, Service 0 , 200, 7
What I'm confused on is why the 'LB::server' field is showing up as '0' in some of my logs, yet shows up correctly in most of them ?
Could this be an indication of a request that was not load balanced at all, and just went to Limbo ?
Thanks !!
- Ian_SmithRet. EmployeeIf you look back through your logs, does the LB::server always equal zero when HTTP::request_num equals one?
If so, that simply indicates that the LB decision hasn't been made yet, so the zero is a placeholder and it doesn't mean that the request is lost; it is present on all the subsequent requests because the TCP connection hasn't been shut down, so that client is connected to the pool member listed in LB::server and no LB decision is being made.
To get the LB::server on the first pass, you would have to request it in the LB_SELECTED event - Randy_Johnson_1
Thanks, Ian !
That explains it completely. - hoolio
If you're trying to get the server IP:port with the existing events, add IP::server_addr and TCP::server_port in HTTP_RESPONSE:... when HTTP_RESPONSE { log local0.info "$request_log_line,\ [IP::server_addr],\ [TCP::server_port,\ [HTTP::status],\ [expr { [ clock clicks -milliseconds ] - $http_request_time}]" }
You can also remove the intermediate variable for response time and wrap the expr operands in curly braces to save some CPU cycles.
Aaron
