simple if statements optimized to switch statements ?
Is there a performance advantage to optimizing the simplest type of if statements as switch statements ?
EXAMPLE 1 :
if { [string tolower [HTTP::path]] eq "somepage.html" } {
pool pool-01
switch [string tolower [HTTP::path]] {
"somepage.html" { pool pool-01 }
EXAMPLE 2 :
set path_lower [string tolower [HTTP::path]]
if { ( path_lower eq "somepage.html" ) || ( path_lower eq "anotherpage.html" ) } {
pool mypool-01
"somepage.html" - "anotherpage.html" { pool mypool-01 }
- Kevin_Stewart
Employee
I think you can pull two rules of thumb from the above:
It's always better to use fewer variables if possible. Variables take up additional memory. So the following:
set path_lower [string tolower [HTTP::path]] if { ( path_lower eq "somepage.html" ) || ( path_lower eq "anotherpage.html" ) } { pool mypool-01 }would be better like this:
if { ( [string tolower [HTTP::path]] eq "somepage.html" ) || ( [string tolower [HTTP::path]] eq "anotherpage.html" ) } { pool mypool-01 } -
A switch is generally more efficient than an if, but the difference would likely be negligible for a small set of evaluations. You'll also find that an if is usually more flexible than a switch. A switch can, at the most, evaluate wildcards with a -glob option, while an if can evaluate regular expressions and beyond. All of that said, I would still probably opt for a switch, when possible, when I have at least two or more evaluations to perform.
- Kevin_Stewart
Employee
I'm surprised it's more optimal to evaluate an expression each time rather storing the result in a variable
The thing is, you're not performing an evaluation with these protocol commands (ie. [HTTP::path]). The information is already stored in the state table for this request, so [HTTP::path] is itself a variable, more or less.
in EXAMPLE 2 , because two comparisons are performed you'd prefer a switch over an if ?
You can really go either way with 1 to 10 comparisons, but I think anything more than that just turns into confusing code. It's a matter of preference more than performance.
- Kevin_Stewart
Employee
What I'm referring to is performing the [string tolower] operation multiple times
Good point, and another good reason to use a switch since it's only done once.
