Norman_Elton_13's avatar
Norman_Elton_13
Aug 05, 2014
Should timing data be gathered for every iRule invocation?
I've got an iRule with "timing on" as the very first line. The CLIENT_ACCEPTED clause then handles incoming connections, either sending them to a snatpool or snat'ing them to a specific IP address. When looking at the statistics in tmsh or the web gui, it shows 744 total executions, even though the iRule has been in place for days, and we're seeing 40-50 new connections per second.
So, question is ... shouldn't my timing data have hundreds of thousands of data points by now? Why does it seem stuck at 744 total executions? I'll include a stripped down version of my iRule below.
Norman
timing on
when RULE_INIT {
 log local0. "Rule initialized with timing enabled"
when CLIENT_ACCEPTED {
 set hsl [HSL::open -proto UDP -pool WM-SYSLOG-POOL]
 if { bunch of logic here } {
  HSL::send $hsl "<190> natipam-f5 $flow_info, Unknown user\n"
  snatpool WM-SNAT-UNKNOWN-USERS
  if { more logic here } {
   HSL::send $hsl "<190> natipam-f5 $flow_info, Invalid user\n"
   HSL::send $hsl "<190> natipam-f5 $flow_info, slot $slot/$position, NAT to $nat_ip\n"
   snat $some_other_ip
  • is the counter increasing after resetting stats?
     tmsh reset-stats ltm rule (name)
  • It reset back to zero, and is now stuck there. My gut feeling is that, after an hour, it will increment to five or six invocations. Double checked that log messages within the iRule are firing multiple times per second, so the iRule is obviously being invoked.
  • it seems okay here. you may open a support case to check.
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 100.100.100.41:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 3
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm rule qux
    ltm rule qux {
        timing on
    when RULE_INIT {
      log local0. ""
      log local0. ""
    root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) show ltm rule qux
    Ltm::Rule Event: qux:CLIENT_ACCEPTED
    Priority                    500
    Executions
      Total                  1000.0
      Failures                    0
      Aborts                      0
    CPU Cycles on Executing
      Average                 51.6K
      Maximum                170.9K
      Minimum                 15.8K
    Ltm::Rule Event: qux:RULE_INIT
    Priority                 500
    Executions
      Total                    0
      Failures                 0
      Aborts                   0
      Average                  0
      Maximum                  0
      Minimum                  0
