jack_39736
Oct 29, 2009shell script to determine Active node in cluster
I am trying to write a shell script for the F5 that will run in CRON to check to see if the device is active in the cluster before doing a "bp config sync".
When I run "set" from the shell, I see that the command:
echo $(getPromptStatus)
will tell me weather the device is active or standby because this is set in the environment.
The problem is, when I try to echo this value within a a shell script, it doesn't have a value. I also tried echoing other environmental variables that are set in the shell but they don't work from a shell script.
Can anyone point me in the right direction with this?
thanks
Jack
- hoolio
Hi Jack,
Can you try ps1 instead?
cat status.bash
!/bin/bash
echo "ps1: `ps1`";
echo "\$((getPromptStatus)): $((getPromptStatus))";
bash status.bash
ps1: Active
$((getPromptStatus)): 0
Aaron - jack_39736
that worked nicely...thanks alot Aaron!
