Tribute2U_25726
May 19, 2016Several IP Forwarding with same destination on same vlan with differents partitions
On BIG-IP LTM 11.5.3 HF3 :
I have 4 partitions on the same vlan and I would like to configure on each partition an ip forwarding with different source (subnet in the vlan) but with same dest...
Kevin_Stewart
Employee
May 19, 2016Can you elaborate? So you have multiple (self-IP) subnets defined for a single VLAN? And you're trying to create multiple forwarding VIPs that source a different subnet on that VLAN? Just for kicks have you tried this from the Common partition?
