Frank_30524
Jul 17, 2008setup failover pair help
I have a acitve stand alone unit that I have to convert to a failover pair. The way we are going to do this is from the command line the 'setup' command and go through the options. I was looking for some insight on this or any help or suggestions. Thanks ... btw F5 says that there is no procedure for this.
- hoolio
You would get more feedback posting this type of question in the advanced config section. There should be an equivalent command line option for every GUI command. So F5 Support should be able to provide you with the commands to do this.
Which BIG-IP version are you running? Is it 4.x or 9.x? SOL2556 has steps to do this via the command line in 4.x:
SOL2556: Adding an second unit to an existing unit to create a redundant pair
https://support.f5.com/kb/en-us/solutions/public/2000/500/sol2556.html
Aaron
