abachman_72712's avatar
abachman_72712
Aug 11, 2009
Setting up Debugging
I would like to incorporate debugging into my following iRule, which I have setup to for the following HTTP_REQUEST to direct traffic by incoming IP address. Traffic being generated is being sent back through the LTM to originator, but if originating member is not available then sends to other member of pool. Traffic that does not match IP will go straight to other pool member.
when CLIENT_ACCEPTED {
set lb_retried 0
if { [IP::addr [IP::client_addr] equals 10.10.10.10] } {
pool soap_pool member 10.10.10.10 9081
pool soap_pool member 10.10.10.11 9081
when LB_FAILED {
if {$lb_retried eq 0} {
set lb_retried 1;
pool soap_pool member 10.10.10.10.11 9081
log error?
  • You can use the command
    log local0. "The client [IP::client_addr] didn't make the grade"
    However, looking at your code, I think there might be simpler way to detect the LB failure.
    What if you change it to
     when LB_FAILED {
          pool soap_pool
          LB::reselect
    This assumes that the pool has a health check, monitoring each node within the pool. Therefore, it would reselect the the healthiest member in the pool.
    I hope that helps
    CB
