rbrianc's avatar
rbrianc
Feb 28, 2019
Setting description for Client SSL profiles
we have several BigIPs running on BIG-IP_v11.5.4. In Client SSL profiles, the API allows us to set a description (b.LocalLB.ProfileClientSSL.set_description). But the GUI has no field to display the description.
Is this changed in a newer version?
Thank you in advance!
  • Just checked this on v14.1.0.2.
    You can add a description to the CLIENT SSL profile via TMSH, but unfortunately it still does not show up in the GUI.
