hamid4411_35059's avatar
hamid4411_35059
Jan 18, 2010
Selecting installation directory for F5 components
How can we tell the F5 software installer to prompt the user for installation folder? the default folder is C:\Program Files\F5 VPN and the installer doesn't ask for installation directory. I would like to allow the end-user to select the installation folder.
Thanks,
  • There is currently no way to edit the default location. Is there a problem with the default?
  • There are no technical problems with the default, but petty as it seems, some customers are extremely dogmatic about where software is installed and are annoyed if they can't put it where they want to.
