Subrun
Nov 18, 2019Select Specific Monitor for Health Monitor "Availability Requirement"
From "Availability Requirement" option of a Pool we can select at least minimum number of Monitor as a Prerequisite for a Pool to be UP.
I have 3 monitor for example I want to specify 2 monitor at least to be UP. But I do not see any option to select a Specific Monitor ?
Any suggestions on how to do that ?
- Simon_Blakely
Employee
There is no way to do that - you either specify that all monitors are required, or a minimum number of monitors of the available monitors are up.
ltm pool http_pool { members { 10.0.0.145:http { address 10.0.0.145 session monitor-enabled state up } } monitor min 2 of { tcp gateway_icmp http } }or
ltm pool http_pool { members { 10.0.0.145:http { address 10.0.0.145 session monitor-enabled state up } } monitor tcp and gateway_icmp and http }You cannot mix the min key option with the and option in the configuration.
