Rise_77519's avatar
Rise_77519
Dec 25, 2011
scripted monitoring with condition
I need a scripted monitor that will work a condition.Client users are using some url links to access for an application.And I have pool members for the application.For instance, if one url link is down, the script will automatically down another pool members that is running with the same url link.
  • just curious if assigning two health monitors to pool and setting availability requirement to all is helpful.
  • Hi Nitass,
    Availability requirement setting would not help me. Because availability requirement would do down all members status if match identified condition.But I need that f5 should reject all client requests incoming to url link when the url link state is down on a pool member.And all pool member state should be up and other url links should work.
  • Hi Nitass,
  • hoolio's avatar
    hoolio
    Hi Rise,
    Are you using an iRule to select specific pools or pool members based on the requested host and/or URI? If so, can you post that to give us an idea of your existing logic?
    Thanks, Aaron
