Danny_Trinh_197's avatar
Danny_Trinh_197
Feb 03, 2009
script for port 443 and 50000-59999
Hello forum,
I have an iRule as below:
when CLIENT_ACCEPTED {
if { [TCP::client_port] < 50000 or [TCP::client_port] > 59999}{
drop
This will allow ports 50000-59999 to be served. I also have port 443 need to serve too.
Does this iRule works on 443 and 50000-59999 ports?
I think it works well for port 50000-59999, but I don't know how to get it works for port 443 also.
Help please.
Thanks,
  • hoolio's avatar
    hoolio
    I think you want to check TCP::local_port not TCP::client_port. TCP::client_port is the source port.
    You can check for the ports you want to allow using this:
    ([TCP::local_port] >= 50000 && [TCP::local_port] <= 59999) || [TCP::local_port] == 443)
    And you can logically NOT that to drop everything else:
         Check requested port
        if { ! (([TCP::local_port] >= 50000 && [TCP::local_port] <= 59999) || [TCP::local_port] == 443)}{
            Request was to an disallowed port, so drop it
           drop
    Aaron
