Jinshu
Cirrus
Nov 25, 2015Script for disable a pool member from a pool which is created using iapp
Hello Friends,
Can you help me to get one script created for disable a pool member from a pool which is created using iapp.
Manually created pool works fine with below script but i need to disable a pool member from a pool which is created using iapp.
curl -sk -u admin:mypassword https://10.x.x.x/mgmt/tm/ltm/pool/Syslog-pool/members/~Common~10.x.x.x:514/ -H "Content-Type: application/json" -X PUT -d '{"state": "user-down", "session": "user-disabled"}'
-Jinshu
- JRahm
Admin
Unless strictness is disabled in the iApp, you won't be able to disable the pool member as the application service created from the iApp template is in control - Jinshu
Cirrus
I have disabled the strict update. But above script doesnt work. I guess we need to go inside iapp folder to get the pool details?
