Saving and retrieving SCF or bigip.conf on/from the LTM using iControl SOAP.
Trying to save (tmsh save /sys config file ) and retrieve an SCF from the LTM using iControl SOAP. The closest solution seems to be System.ConfigSync.download_file or System.ConfigSync.save_configuration with the "SAVE_HIGH_LEVEL_CONFIG" flag, which saves to bigip.conf. I would also like to retrieve either the SCF or bigip.conf to our config mgmt server.
Thank you.
I wrote a sample a long time ago illustrating how to use the ConfigSync interface to save/load configurations as well as upload and download files. Given the correct file path that the iControl Portal has access to, you should be able to download a configuration file.
https://devcentral.f5.com/codeshare?sid=122
-Joe
