Franz-Joseph_Kr's avatar
Franz-Joseph_Kr
Apr 19, 2006
Sample SystemInfo.pl is not working.
I just startet with iControl SDK, so i thought it might be best
to try out some of the provided samples.
I am using XP as Client.
But allready the first (SystemInfo.pl) is not working.
We have SOAP Lite installed and Perl Version 5.8.8.
Starting SystemInfo.pl via:
SystemInfo.pl 10.250.30.86 21 username pwd
I just get the following output:
System Information
500 SSL negotiation failed: at C:\iControl-9.2.2\iControl-9.2.2\sdk\samples\soa
p\perl\soaplite\System\SystemInfo.pl line 89
Am I using the wrong port?
The Host-Ip Address is 10.250.30.86 (Custom HostIp)
but I could not find any information about the used port in the
BIG-IP Admin Tool.
Can any mody give me a hint.
Would be most appreciated.
Francis
  • Have you installed Crypt::SSLeay? Instructions are here:
    http://devcentral.f5.com/Default.aspx?tabid=29&articleType=ArticleView&articleId=17
    Click here
    -Joe
  • Thank you for your support. It turned out, that port 443could not be reached due to a firewall. We are running SystemInfo.pl via a Unix-client. It works fine now.
    I could just no figure out, were to put new skripts. They are working fine if we run them under the samples directory. But I could not find any infos about how to run scripts from other directories. Sorry, might sound stupid, but it's just my 4'th day with perl.
  • The samples should work fine from other directories, just copy the iControlTypeCast.pm in the sdk/samples/perl/soaplite directory to the new directory you placed your scripts and all should work.
    -Joe
