SAML for Chromebooks advanced integration
Hello
I'm hoping someone clever can help me. I have enabled and can use SAML to login to Chromebooks but Google say there is a way to pass through the credentials to the Chrome browser so that after login the SAML is still in the users session. They advise to call an API:
https://www.chromium.org/administrators/advanced-integration-for-saml-sso-on-chrome-devices
I don't know how to invoke or insert this JavaScript or where. Any ideas?
Regards
Stuart
- Andy_McGrath
Cumulonimbus
How are you relating this to F5?
- StuKirby
Well as I'm posting on the F5 forum under the APM section I thought it obvious that my SAML is via F5 APM.
- Andy_McGrath
Cumulonimbus
You have posted a link to a Chromium doc related to using SAML within a Chromebook without directly stating you are using an F5 APM as a SAML IdP and also assume we all have the time to read up on 'Advanced Integration for SAML SSO on Chrome Devices'
If you don't make it clear you will not likely get the help you are after.
However, I think want you need to do is create a customised logon page within the APM and add in the JavaScript, linked to in the documentation, and write a bit of additional javascript around the login form calling the three methods:
- Once at the start of the authentication flow.google.principal.initialize(callback)
- When the user has finished entering his/her credentialsgoogle.principal.add(details, callback)
- When user’s credentials have been verified by the SAML IdP and the user is authenticated.google.principal.complete(details, callback)
Basically this is a locally executed process via javascript but needs to be provided by the logon page/form without interfering with the F5 APM authentication process its self.
That is until you get to the
method as the F5 APM needs to pass thecomplete
andRelayState
to a Google URL.SAMLResponseFinally though I do know Javascript I only really write back-end stuff and never front-end web stuff so not sure on the best approach for this, need someone with some front-end javascript experience I think.
- moureg16
Cirrus
hi there , I’m working on using F5 as a SAML idP and I need to emulate a SaaS as SP. I faced a lack of knowledge a round related to how to create such lab “the application demo” to use it as a SP
anyone to help, please !
