nanukanu_263047
Dec 01, 2016Same VLAN SNAT
It's possible to do SNAT in same VLAN? I want to balance between servers on the same vlan.
Regards!
Yes, this is possible.
- Vijay_E
Cirrus
You can probably achieve this with SNAT Automap. If you expect the number of connections to be more than 60K, I would recommend using a SNAT pool within the VS. SNAT configuration guide.
